Northshoredoug
does anyone know how the rod bearings are designed get oil on a 27hp 49T877 series Vtwin?
there's pressure passages from the pump ported thru the case that flows thru the cam to the crank main journals and there are 2 oil holes in the crank rod journal but they dead end there and do not connect to the mains on the crank?
cant for the life of me see how the rods get oiled on the big end,
this is a new motor had a knocking rod and I'm wondering is it possible the crank wasnt cross drilled from the mains to the rod journal and they sent it like this from the factory? or is it not pressure fed to the rods? anyone have a repair manual that shows the lubrication pathway?
49T877-0010-G1 27HP commercial turf
