Z425 Motor replacement
rubantin
My mower stopped running today. When I turn it over there is a very loud double clunk with each rotation of the crank. So, I don't think I'll be taking the time to investigate. It has 800 hours and when I took the shroud off there was a lot of fur packed around the cylinders :(. So, I am sure it's toast. Anyways it is a 24hp 44L777-0144-G1 and I can't find a replacement for less than $1200. I found a new 20HP 40N877-0059-G1 that should drop in for $600 new.
What do you think?
I’m not sure of the compatibility between those two engines, but if you are patient I’m sure StarTech will see your thread and be able to help you out. I really don’t like the guy, but you can trust his recommendations. Really good head on his shoulders, but I think it might be cross threaded.
You don't want to drop 4 hp especially with 48" or 54" deck.
JD Parts don't even show a 42" for the Z425 model.
But they do show an Briggs 40H777-0152-B1 as a replacement.
rubantin
I dread the idea of pulling that engine apart....
rubantin
well? I just found a new 44S9770032G1 for $925... Would that work?
That is the Briggs recommend replacement for the current engine.
And you getting a fairly good discounted price and it is actually less what the short block costs me. Now you know why we don't rebuild many engines anymore.
