Tubes into 15X6.00-6NHS HOW!!!!!!
Search tyre lube,
Every auto shop carries it
every tyre shop caries it
AS for inflating, I just take the valve out and use an air duster that has a very large hole in the end of it .
That will seat the beads ( usually ) although warming the tyre or stretching it by putting a tube in it blown up for a day or so helps reshape the tyre .
Yes the inner tube trick works very well for those tire with three shipping flat spots or those sidewalls that won't seat well otherwise.
Hammermechanicman
You mean the 4 ply rated ones smashed flat and banded and stored that way for years?
