LawnWizard
Trying to sort a charging issue on Ariens Max Zoom 60 / Kohler Courage Pro 25. Just acquired used. Dead battery. Former owner said the blades quit the the engine died. I assumed bad battery. Partially correct, battery would not take charge from charger. Replaced, started, ran great. Shut off, had trouble restarting. Checked voltage 12.6 at battery. Checked fuse (only found one 25 amp). Checked all battery connections. All tight, no corrosion. Checked voltage at middle wire of VR. 0V with key off / 0V key in run position.
Installed new VR. Still showed 0V key off but 12.5 key on. Checked AC volts on outside wires of connector = 40V AC with engine running. Started engine- still 12.45 coming back to batt. Retested VR now 0V on center wire key off or on. Also almost 0 with enrunning WOT. I'm assuming the new VR is fried? Question is why? And where is my open pos? If stator was bad, why 40V AC? Is there another fuse somewhere?
Any suggestions will be greatly appreciated.
