rajthepilot
- Jun 1, 2023
- Threads
- 8
- 23
Hi All,
My battery died on Saturday and I bought a new battery on Monday and it showed 12.57 volts, but when I started the engine it was showing 12.45 volts meaning it wasn't getting charged by the stator (alternator). Perhaps the old battery wasn't bad and I shouldn't have returned it, but all good. I had jump started it few times last year, so I thought the battery may have been the issue.
Then I opened it up and checked the yellow wires coming from the stator and they showed around 33VAC. Then I checked the red wire coming out of the voltage regulator and I touched the red multi meter lead to that and then I touched the black lead to the battery's black terminal and it showed about 1 volt or so, so I figured the voltage regulator is the problem. After I turned off the engine, I was expecting to see 12.57 volts between battery's black terminal and the red wire going from the voltage regulator (not coming from it, but that connects to it and goes to the battery) and I got 0 volts. I was expecting to see 12.57 volts on it. i even turned on the key to the on position and still didn't see it.
When I attached the new voltage regulator today, I got about 5 volts when I touched the red lead to the red wire coming out of the voltage regulator and the black lead to the battery's black terminal.
1. Is there any way to test the voltage regulator when the engine is not running.
2. How can I test the voltage regulator's output while the engine is running without connecting the red wire to the mower (I thought I could touch the output red wire and the bolt that connects the voltage regulator to the mower (I thought that would be negative) but that didn't work
3. How can I verify that the wires after the voltage regulator are good ( I thought I should see 12.57 volts when I connected to battery's black terminal and the red wire going from the voltage regulator)
Thank You
Thank You
