SpoolinV70
- Jun 9, 2017
- Threads
- 10
- 54
I've been trying to sort out the choke on a GCV160 powered Craftsman lawn mower, and I'm getting a bit frustrated. I initially ordered a replacement carburetor with a manual choke lever, which I soon realized was incorrect, as this mower has an auto choke lever. Got the correct carb, installed it, and the auto choke isn't working properly. It doesn't ever adjust, it just keeps the choke flap closed.
Now the problem is that this engine seems to have the only Honda auto choke design that I can't find any information on. The later thermo-wax style choke is well documents, as well as the semi-auto choke design. This one is a little different though, as it seems to be a thermo-wax setup, but it's integrated into the whole choke lever assembly.
I did find it on parts diagrams, however the part isn't listed. I'm assuming the only problem is the wax element, as the springs and lever are all working smoothly. Does anyone know what I could do here? Would I be able to just swap to the other thermo-wax auto choke lever? I already have the wax element for the other style, but I'd have to double check the engine casting to ensure it as the opening in the right spot for the thermowax element.
Part 21 in this diagram https://www.jackssmallengines.com/j...n-gjaea-1000001-to-gjaea-5386302/carburetor-2
Pics:
https://photos.app.goo.gl/U5HUPVLeeHd7wwiF7 (the element itself that I removed from the housing)
https://photos.app.goo.gl/sLrupe8X95xArP9Z6 (the back is loose since I had removed the screw, taking it apart to inspect)
Pics:
