Uneven cut
MParr
Have you replaced a front or rear tire? Tires that are stamped the same size might not be the same size. Air pressure is critical too. The air pressure should be the same on both rear tires. Most lawn tractors get 10 psi in the rear and 15 psi up front. Watch this video.
terrye
Tires are correct size and correct air pressure. I have found a rather large dent on the left front of the deck.
MParr
You might find more wrong when you pull the deck out from under the mower.
