Amateur
My 407777-0167-e1 (20 HP twin OHC Intek) bent the intake pushrod. I have a replacement and I put it in. When I manually rotate the engine I don't have any problems. That is, the intake valve seems to depress just fine. Can I run it again without adjusting the valve guide? or is the valve guide going to cause issues at run speed?
Also, I am not able to remove the valve stem seal and have ruined the rubber trying to remove it. Any advice for how to take it off? The only advice I've seen is to use slip joint pliers, but that ain't happening. I'd hate to have to get a new head just for this.
Thanks in advance.
Thanks in advance.
