junkman108
Els 40H777 . One cylinder has 160 psi clean plug other 65 and plug is oily. Could it be valve lash? If not im guessing head gasket or rings.???
No but a head gasket is cheap and it only takes about 1 hour to changeThis is cyliner on left. The intake valve lash is .003 the exhaust is .029. Leak down test wont distinguish between head gasket and rings will it? Both going to blow into crankcase ,no?
Yeah it was filthy. I slapped it back together ot still has same 65 psi with used head gasket going to run it until it blows or makes it to fall. I got a kohler command cv20 in storage.Looks to me, blury pic and all, that the engine was over heated. Look at the aluminum that was deposited on the bore. Or is that some plastic??? Can't tell from the picture.
Has the engine cover ever been off and checked for clean and clear cooling fins? Post a picture with the engine cover off.
