IS2100Z deck idler pulleys
greenguy
anyone have a source for the idler pulleys for the 61" deck, model # 5901344, they seem to be discontinued on the Ferris parts .
Thank you, the problem is, they are not even listed, so I don't have a part number to search for.
PN 5102831 use Stens 280-491 or Rotary 12472. Prefer Rotary ones here.
Thanks for the reply, I haven't removed the pulleys, just want to have some on hand. The diagram shows quantity of 3 for item #6 and quantity of 1 for item #13, I would assume the pulleys are different??? Thanks again for the reply.
#13 is Ferris 5104716 (Rotary 14942). It is also the Briggs 5104716YP
I fit standard idler pulleys bought from an engineering supply company
They come with jst the bearing in the pulley so I have to push the old stand off bush out of the old pulley and fit it to the new one
All of 2 minutes work that halves the price .
And reduces waste to boot .
Any more info on which company you get them from? Thanks for the response.
