charles.harward
The mower started just fine at the start of this season. Then it started back firing on some restarts and now it will not start. I have looked at the fuel pump and it's fine. Looked at the carb bowl and it was clean although I did not clean the jets. Tried using start fluid to no avail. Didn't even try to start. Looked at the spark with a spark tester. It fires with no misses, bur the spark is yellowish. What do I do now?
