Hydro gear 335-0510 spring assembly
Ok here's what I got going on now. The spring hooks don't line up with anything. I do remember taking off the castle nut for some reason but don't remember why. Unless that spring twists 90 degrees for some reason and fits where the castle nut is.
Okay let's try a 311-0510 setup.
First place the brake springs back where we started.
Now see if this diagram is closer. Hydro Gear does make changes without notice sometimes. I was going by the service manual. Let's try putting the heavier spring at the arrows that is if the hole in the side case is there. But if the image of the side case does show it being there.
Ok. It just doesnt seem to line up. Im sure this is something so simple thats once I finally figure out where it goes ill be like oh yeah, duh.
Okay went through the Hydro Gear dealer site and found they have done several changes over the years. The spring you have is severely damaged or simply the wrong one. I could only find a line drawing of the spring; no specs on the spring size or length.
What you could do is the use the 51345 is both places with them attach to brake caliper bolts.
Hey guys, I need help installing springs on a 2003 mtd yard machine that has right hand speed control. I removed the hydro from tractor and for the life of me cannot figure out how the springs on the right side go. Down by the brake. I've researched everywhere and cannot find a picture of what spring goes where. Also if you guys have pics of where the hydro installs to the mower itself through the linkages. Thanks a bunch
Does it have more than one hydro on it. Are we talking about a o turn machine.
Yeah me too. The mower worked when my brother brought it to me. I took the hydro out and a few days later went to put it back together and just cant remember where the springs went.
I always take pictures of anything I start to work on. I don't trust my eyes and ability to remember how things go.
