Hydro gear 335-0510 spring assembly
Hey guys, I need help installing springs on a 2003 mtd yard machine that has right hand speed control. I removed the hydro from tractor and for the life of me cannot figure out how the springs on the right side go. Down by the brake. I've researched everywhere and cannot find a picture of what spring goes where. Also if you guys have pics of where the hydro installs to the mower itself through the linkages. Thanks a bunch
mechanic mark
Need Model & Serial #'s from MTD tractor, possibly under seat. Why did you remove transaxle?
What springs
There are lot of springs for different reasons
Some photos as well as the information requested by Mark will be very handy .
Well I can't post pictures because the file is too large for the server. But the model number for the mower is 13AD698G300 and serial number is 1D083B70141. Basically the spring looks like a heavy duty spring. And I'm thinking it goes on the right side of the mower by the brake assembly somewhere, above the bypass valve
Okay does it looks like this?
Image 1
or this one
Image 2
Here a couple images of where these goes.
Well resize your photos to 12" on the longest side @ 72 DPI
There are compression springs, tension spring , clocksprings
Spring does not tell us much.
Heres what I have. Not sure if everything is in the right place or not
