Blacktrain11
I have a Cub Cadet LTX 1040 Model #13WX90AS009 Serial #1C150H60087 When you press on the pedal to go forward it takes off like it should for about 30 feet and then gradually slows down to a stop, let off the pedal and press down on the pedal again and it will take off again like it should and gradually slows down again to a stop it about 30 feet. Reverse is normal. I replaced all belts and a new variable speed clutch. Any help would be appreciated. Thanks...
