I have been given a Sears Craftsman 2 stage snow thrower 24 inch 177 cc engine. It is a model 247.889571 This machine was made for Sears by MTD and has a MTD Chinese made engine model 265SU. It has a broken connecting rod. It was run low on oil and the rod seized on the crankshaft. I can see that aluminum from the rod has fused itself to the crank journal. I think there is a term for this metal transfer. I am considering replacing the connecting rod and the crank if necessary. The rest of the engine and the snow thrower itself is s in great shape and seems to have been lightly used. The piston and cylinder show no scoring or discoloration at all. the rings are all in good shape loose and flexible so I think I have a chance to fix it. I have seen some videos of removing the aluminum using Muratic acid on the crank journal. is there anything that I should be aware of for this type of procedure?
I have replaced a couple of crankshaft on vertical lawnmower engines...this will be a first for me on a horizontal engine. Any and all I guidance is welcome
thank
CFS
Alan
thank
CFS
Alan
