Tire Chains
Swarf
Tire chains are likely to be thought about at this time at year. They are expensive here in the UK and I feel they are just grossly overpriced.. A 10 M length of 6mm ( 1/4") plated chain from Toolstation is £19. and makes a set of chains as shown in the photos. NO welding, just cut and twist links. I have these on a STIGA Park mower when on wet slippery rough ground. the attachment is a 3 foot wide flail, or in U.S.A. (hammer knife) ... Fit chains tight with shackles or screw links onto deflated wheel then pump up. Perfect ... Chris.
