Needing a Used Carburetor
dnkjr
For anyone who may be parting out an old rider. I am in need of a rebuildable carb for B&S Model #42A707, Type#1238.01, Serial #9606115B.
Any help or sources appreciated.
Text me @512.705.9030
sgkent
Forest#2
Thanks for the info. I had not thought of that.
Free money back returns if it don't work properly.
If it don't work ok get another. Don't be surprised if it don't act smooth.
Craftsman Garage
What is usually do is buy one of those aftermarket carbs and use those new parts to rebuild the old one. Don't use the aftermarket carb shell! They don't make them to the quality standards of the old ones!
Forest#2
link too several. (keep your old one if you still have it.
You can get just the 4 screw or 3 screw pump only kit by itself if needed.
Here is a link to se3veral on fleece bay. Seen a used one for $20 free ship and 30 day returns. Them carbs usually re-build user friendly.
Quite often if one has been running smooth and then starts idling rough just remove the bowl drain plug and re-install and get a good run.
The more user friendly ones have a idle adjustment jet.
