Berniebac
- Apr 8, 2012
- 185
I purchased a B & S generator a few years back. I got it after a storm left us without power for a few days. Never used it till this weekend when hurricane Fiona left us without power for about 48 hours. So it had been sitting in the basement for a few years never having been run.
I started the generator and found it running a little rough. The exhaust smelled pretty bad and it seemed like it was running a little rich. I used it off and on for a couple hours at a time and each time I started it a small puff of black smoke came out of it. While it was running I removed the air cleaner cover and thought it ran a little better, I also removed the air filter but did not see any more improvement. Having no experience with it before, I thought it was burning fuel quite quickly, as it ran about 2 1/2 Hrs on 1 US gallon (3.78 liters).
I think it could use a little carb adjustment but have not been able to find any adjustment screws on the carb. I have not taken the plastic covers off of it as I would like to determine if there are even adjustment screws on the carb. Photos of the unit below and what information I can find on the engine/body of the unit.
Unit Info:
Briggs and Stratton
P2200
Mod. REV
030051-00
Year 2018 Jun 2018
Disp 111cc
EXH Family JSEMS.1111SM
EVA Family JSEMPNHE0001
Carberator Make: Huayi
There are numbers on the carb. around the top of the bowl but I can't see them all to include them here. I do not see any numbers for Type, Code, etc but they may be on the engine and I might have to dig a little deeper to find them
I don't know if this is enough info to help me adjust the carb, but if you can provide some insight I would greatly appreciate it.
Unit Info:
Briggs and Stratton
P2200
Mod. REV
030051-00
Year 2018 Jun 2018
Disp 111cc
