sgkent
- Sep 27, 2017
- Threads
- 35
- 1,787
it sure the heck will if the engine is overheatingCooling system would not have an effect on oil pressure.
If the engine is overheating, one has bigger problems than a low oil light coming on. Please educate me as to how a low oil light would be a temperature issue. Thanksit sure the heck will if the engine is overheating
He didn't mean it like you wrote it down. Slow down, take a breath and reread this entire post.Please educate me as to how a low oil light would be a temperature issue. Thanks
"New oil pressure switch, regardless of brand, doesn't mean it works like a new switch." WHAT? That makes zero sense.New oil pressure switch, regardless of brand, doesn't mean it works like a new switch.
Yes overheats can thin some oil. Bet the top engine shroud has never been off. Valves never been looked at. Cooling fins neglected for sure.
