Kaw fh580v smokes black and surges-hunts
Red Good
This is a motor I rebuilt prev owner ran no oil . New rods ,pistons , crankshaft , fresh honed cylinders , recut valves and seats , all new seals and gaskets , welded the window in the cases , fresh oil and filter . Starts and runs well for a second and then starts to puff black smoke and hunt , recleaned carb , drilled out both welch plugs and ran a strand on electrical wire through everything . Noticed the skinny little tube had serious corrosion/staining on it . New welch plugs installed and reasembled same thing . Ordered a new Kawi carb . While waiting got it hot and did a compression test , 150 both holes , plugs are sooty as expected . , rechecked coil distance at .010 ok . ran motor with neon plug tested on it , no misfires or anything weird . Install new Kawi carb and it runs exactly the same . Cannot be the carb so checked the fuel pump looks like fair flow , started it and run it and used a pair of pliers to pinch fuel line to about 1/2 flow , takes a minute and it cleans up and runs fine . Release the pliers and it goes back to hunting and smoking black . What the heck is going on ? Any ideas ? 40 years at this and never ran across this . Its on a Toro zero turn maybe 10-12 years old . Help
Try running from a spare tank hooked directly to the carb gravity feeding
IF problem goes away then either the fuel pump diaphragm is punchured or the new carb is for a gravity feed system .
IF the pump is fine, try heating & bending the tang for the float so the float closes earlier .
Red Good
Tried that this morning , gallon test can 12 inches above the carb , starts and run puffs black and hunts same as before . Tank has a knob to shut off fuel so turn it 1/2 off and it starts to get better at 1/4 it runs really nice . Are jets available for these carbs , cannot find a size on the stock jets . Thanks guys .
hlw49
Check the choke.
So we are making progress,, sort off
has to be in the carb.
Stock jet should be 92063-7037 which is a # 105 size
Have you tried backing out the pilot air jet on the top of the carb
This actually does make a difference to the dynamics of the fuel flow in the main jet
Also double check the timing key because if the key sheared when you were holding & tightening the flywheel that will lead to a ******** spark
I used to check the valve timing & Spark timing by wrapping some masking tape around the flywheel then I came across this app on the web to print out timing tape.
If you print it onto self adheasive paper it will stick to the flywheel but I use plain paper & spray glue
timing tape printer
timing disc printer if you prefer
Old carb needs to be pressure tested at the needle and seat. New Kawi carb was never tested either.
So stopping down the fuel flow, engine cleans up and runs better. Tells me the needle is sticking open and likes your new 1/4 valve opening to get proper A/F ratio.
Red Good
timing tape printer
Will check the wheel and key , 3 carbs now all the same ,pilot adjustment in all the way out all the way makes no difference . leads me to beleive its not the carb . Thanks guys .
Pressure test the carb needle yet?
