will not move forward or reverse.
Jay P
Used the Toro 42 Timecutter to mow and drag high school softball field. When finished shut it down to allow it to cool and to clean off before putting away. When we restarted the mower to put into shed it will not move in any direction. started fine , belly will move up and down and blades will engage.
Did any of the school kids pass by
Funny trick to open your bypasses
What he said. You're neutral knobs may have not been tight enough. Definitely check the drive belt too. If it comes off, it can be difficult to spot (and put back on).
