Colonial Scottish, and Cherokee (probably Pamunkey), and also one of the Plains Tribes on my Grandmom's side although I did not learn about that until a year or so ago because her mom and dad divorced, and the Plains was on his family's side. Her father's family reached out to me a few years back when they realized their shared father had her in a prior marriage. The Scottish, and Native Americans didn't always get along that well during the 1600's and 1700's. So whom do I root for when they are fighting each other, my Scottish side or my Native American side? And there was some Scouting in there toosgkent,
My ancestors were Colonial Scot and Native American.
Should be Colonial Scout isn't it? Simple typo?
So below your message body you have a blue section about your ancestors. That is what I was talking about.Colonial Scottish, and Cherokee (probably Pamunkey), and also one of the Plains Tribes on my Grandmom's side although I did not learn about that until a year or so ago because her mom and dad divorced, and the Plains was on his family's side. Her father's family reached out to me a few years back when they realized their shared father had her in a prior marriage. The Scottish, and Native Americans didn't always get along that well during the 1600's and 1700's. So whom do I root for when they are fighting each other, my Scottish side or my Native American side? And there was some Scouting in there tooduring the War of Independence. My gg-grandmother was secretly raised by her grand uncle, Gen. Francis Marion, The Swamp Fox, when her father, (his nephew) was killed by the British during that war.
Yes, I removed both kill wires when the coils were swapped. The tach did act up on both sides with the kill wires removed. Putting the spark tester inline was the only thing that stop the needle from swinging at high rpms on either side.When you swapped the coils over, did you try it with the kill wires removed ?
I ask this because you can get feedback ( which is what the diodes are supposed to prevent ) from one to the other
The fact that you got a faultering tach reading on one side & not the other points towards a bad magneto.
Also have a good look at the rockers
the cam grinds are identical , the followers are identical & the valves are identical
So if the cam is good both pairs of rockers should sit parallel at firing time & move the same amount.
If the head overheats then one of the guides ( usually the inlet ) can slip in the head so the inlet rocker will be out of place .
I pulled the large nut off and the key looked perfectly straight. I bought keys just in case, but I didn't want to pull the flywheel if I did not have to.So brother, this is puzzling. Again flywheel key just a micro tick off? You said it was checked already.
Could be excess fuel or air, SOMEHOW, getting into the muffkin, maybe dripping into it??
Carb needle and seat pressure tested to 7psi, holds for 30+ minutes?
Think your exhaust port needs pressure tested with 20-40'ish psi. These car evap system smokers are 1psi and under. Think they are 1psi MAX pressure.
Yes, the intake manifold bifurcates to two cylinders. There is only one outlet port.does the carb have only one outlet, and then the intake manifold bifurcates into two cylinders?
Pull the oil dipstick and smell for gas.I should have replaced the float needle but it was $16. I don't see any issues with it flooding or running rich on the spark plugs. The needle and seat looked new.
I used gumout multi-tune in the oil and blaster lmt in cylinder 2. There could have been gas. I changed the oil 2 days ago and so far no gas smells or change in the oil level.Pull the oil dipstick and smell for gas.
Still need to pressure test the needle for 30 minutes at 7psi.
