Hi Ya'll, I have a Briggs Intek Single 18hp on a Troy-Bilt rider.  Very generic.  I have watched many videos on doing the valve adjust.  One will have you set the lash by setting the engine at a point where one valve is open and the other closed, and another has you going to 1\4" past TDC and setting both valves at that point.  Which is better?  Secondly, some say to set them both at .004", others say set to spec.  Again, which is better?
I don't have the manual, but it was said the manual says set engine 1\4" past TDC and adjust both closed valves to spec of I= .005" and E= .10".
Thanks
Thanks
