84MonteCarloSS
 - Jul 8, 2022
- Threads
 - 1
 - 2
Howdy y'all. Picked up a Murray Widebody LT the other day. Has the Briggs 18hp Twinii. She's a L head. Been sitting for a while. Brought her home and found she had no spark. Went to local Dealer and bought a coil. Now it has spark, got it running and it won't idle. Anything under half throttle it will stall and it only runs smooth with choke closed about 5/8s of the way. Did a Carb clean, New Plugs. New Gaskets. I even removed the carb spacer incase it had a crack in it but still no luck. I'm 16 and went through everything I would know. Checked Valves, they aren't stuck. Has Great Compression and plenty of spark. I'm thinking intake itself may have a crack but not sure. It's pretty late, got work tomorrow, Tomorrow is another day. If anyone could throw in some input it would be much appreciated. Thanks in advance -Mike
