HUSKEE LT4200 DECK SPRINGS PLACEMENT
AngelaBruce
Does anyone have a simple photo of the top side of mower deck, taken from overhead, that shows everything in place? No drawings or diagrams with 1000 pieces and parts and lines. I am looking for placement of deck springs.
Huskee is just a retail name for mowers sold through Tractor Supply Company so as a brand they do not exist
At one time it was made by Roper then AYP then MTD
So without the model & serial numbers we are flying blind.
AFAIK never made by Murray
No mention of any Huskee colour codes in the Murray parts catalogue I have .
Also the deck size & configuration would be handy
The only one I can find has a manual blade engagement via a cable on a 42" 2 blade deck
The only tension spring on the deck pulls the tension arm back to apply the spindle pulleys brakes .
The cable has a spring that fits on top of the idler pulley bolt to pull the pulley on & engage the blades
The brake has a clock spring under the lever
Howeer this could be a different deck because without the number we are flying blind .
13W2775S031/231
MTD 42". one of several designs.
It be tomorrow before I can get a deck off and imaged; and that is if it is not raining, right now it is dark and raining.
PTO engagement cable spring and Idler arm return spring.
LH Spindle Brake Spring
