PTmowerMech
I just replaced this carburetor and fuel filter a couple of months ago. Was mowing when the Kawasaki started acting up. So I removed the fuel solenoid and let the fuel drain into a clean container. There was a lot of rusty colored specs. So I removed the float bowl and is was an 1/16" thick with that same stuff. Just like before. The bowl was rusted, the main jet was getting clogging. The needle was sticky.
I got the tanks gas drained out then rinsed it with water a few times. I noticed some small plastic pieces come out. After emptying all the water out, I could hear more plastic pieces rolling around. So I fished them out.
No diagram I've found shows this one particular piece that shaped like the valve out of a head. About 3" long, plastic. The head is a little bigger than a quarter and has a black rubber O ring on it. . There are no holes in it, what so ever. None going up through the center. I can't imagine this being connected to the fuel line. The fuel line assembly (04320900) has nothing that looks like this.
Since the fill hole has a splash guard glued to the inside, I can't really see inside and where this may have come from.
The only thing left would be something to do with the vent. In which there are no pictures that I can find on diagrams. But the valve looking piece doesn't fit the actual vent that I took out. I'll look tomorrow (where I rinsed out the tank), but I didn't see anything that would join the vent and the valve.
And nothing explains why there's a robber o-ring about the big end of the valve.
On a side note, allowing all that trash that got passed the Stens fuel filter, makes me question their filters.
