I found the fuse, hidden, but found it, replaced it and mower fired right up. Now I am trying to diagnose why the fuse blew. This never happened before, I noticed right before the mower wouldn't start back up (fuse popped) that my blades would not disengage. After looking into it, it seems there is a sensor that knows when blades are or are not engaged. Obviously it will not start with the blades engaged.
So, I was playing around with the cables/detent etc to try and get it to engage/disengage. During this I accidentally had the key on, as I manipulated the cable spring, I grabbed the exposed cable and burnt the snot out of my thumb. Is it normal for the cable to be electrified? Now I need some help diagnosing why my fuse keeps popping. Thanks for any help
