tenisprola
Frustrated beyond words. 2006 model with lots of repairs along the way .
Started it after winter storage, and it caught fire (after 1 hr use ) because of a mouse nest.
Poured cold water on it in a panic , but luckily don't think i cracked the block.
It did start immediately . Cleaned it up ( temp repair on spark plug boot ) also fixed leaky cork valve cover gasket( 10 years of oil leak ) , and replaced melted plastic fan cover.
Was working fine for 2 mows then started idling slow and eventually puttered out . Starter would not turn it , but could be turned ( lots of resistence ) by hand .
Thought it was starter , so disasembled & discovered 3 of 4 magnets unglued. used JB weld to glue magnets on and assembled . Starter still unable to turn flywheel more than 1/4 rotation .
Opened up valve cover to discover rocker arm loose,(set screw almost off ). Tightened back up and the flywheel was back to normal and would rotate freely by the starter.
Mower still not firering up . Was using 1 year old fuel , so took fuel tank off and drained / replaced with fresh fuel.
-fuel pump( replaced with CC original part): has flow into carb intake hose upon engine cranking .
-fuel filter ( not clogged but replaced )
-ignition module (lights up tester with flywheel rotation ) but replaced with CC original part
-carburator ( replaced with non CC original part ) , solenoid seems to engage ( clicks with key turn)
-took flywheel off ( cleaned ) and checked for sheared key /woodruff key looked intact
- adjusted valve clearence to spec per manual ( at TDC of compression )
-changed spark plug and gapped
- made sure throttle and choke linkeages work properly
-it has oil to proper level
-by passed seat safety switch
-by passed brake pedal switch
-air filter and housing off
-bought new CC original starter but not intalled ( original starter working )
-made sure not to reverse polarity of magnets on glued starter by checking rotation of flywheel against that of new starter , and has same clockwise direction
-sprayed stater fluid into intake and cranked but no ignition
please help .....What should i check or recheck next ?
