B bk10s Well-Known Member May 23, 2022 #1 18 HP Broadmoor. Heard something flopping around today, and noticed that the drive belt is loose. Is there an adjustment for that? When I replaced it a couple of years ago, I used the Simplicity OE belt.
StarTech Lawn Royalty May 24, 2022 #2 These decks should be using two spring loaded idler pulleys to keep tension on the two belts [self adjusting]. Probably one the springs has broken.
B bk10s Well-Known Member May 24, 2022 #3 The deck belt is fine. The drive belt is loose. I will get under there today and take a closer look.
StarTech Lawn Royalty May 24, 2022 #4 bk10s said: The deck belt is fine. The drive belt is loose. I will get under there today and take a closer look. Click to expand... Sorry about that. That I get for having a bad headache the last two days and was up at 3:30 am here. It is the same advice as there is two springs shown on the ipl. Plus check the idler pulleys themselves as bearings do fail. It is also possible a stick gotten into the drive belt path and caused the belt to thrown off. As far adjustments there is none as springs are used to auto adjust the tension. Once the belt is too worn then it has to be replaced.
B bk10s Well-Known Member May 24, 2022 #5 I guess this would explain it! Attachments IMG_5981.jpg 408 KB · Views: 5
