I will hazard a guess here that the actual governor mechanism has failed
What usually happens is the engine then over revs and the con rod snaps just below the little end from over reving.
So the broken con rod was not the cause, it was the symptom .
To understand the way things work consider it to be a tug-O-war between the governor spring and the governor.
When you open the throttle the spring stretches
When at rest the governor is fully open so the throttle opens fully
as the speed increases the governor pulls ( pushes if you like ) against the spring
The governed speed happens when the tension on the spring is balanced by the governor working against it
So the governor is always trying to make the engine go slower but the force it does this with is dependent upon the speed the engine is rotating at.
zero rotation = zero governing force
High rotation = strong governing force .
In practice a governed engine should run forever so when something internal breaks you always have to find out why it broke before you replace it .
Mower engines are made very cheaply so the con rods are not particularly strong
Most will let go at around 5000 rpm because the engine is designed to never exceed 3600 rpm ( 3200 for most Hondas )
A rookie mistake when using a mower engine in a go cart or mini bike was to remove the governor and use a direct throttle control and a broken rod is the usual result .
"it was running great, then it just went bang & stopped " is something I hear regularly from the racing mower mob
