Replaced head gasket
Have you tested for no compression? As in with a gauge?My Briggs and Stratton 11092-0113 f1 single cylinder overhead valves has no compression. Replaced head gasket,seated and adjusted valves. Was wondering if I need to replace the camshaft? Would the camshaft cause me not to have compression?
A bad cam could cause no compression.
Remove valve cover and turn the engine over. See if the valves open and close. Maybe the rockers are not set proper? Bent push rods?
Which stroke were the valves set on? There are 2 TDC strokes on a 4 smoke engine.
Did you lap the head and head gasket area prior to installing the new head gasket? This needs to be checked.
i just do one valve open, one valve closed, adjust the valve that is closed.How do you know which TDC stroke to use to set valves? Is there a way to determine which stroke is the correct one to use?
