Thanks but url does not work for me.This service manual may be of some help. http://www.gaaged.org/docs/sidemodules/38782_276781SingleCylinderOHV.pdf
Correct as usual.Then do a google search “Briggs single cylinder OHV service manual pdf”. That springs will go around the throttle link and hook into the same holes as the throttle link.
Put it in the same hole then.Thanks seems clear but does not show very thin wire with light spring on it, I think it may hook into small hole on governor arm just below main link back to I don't know where.
