151230 98 70774 model #
Star, I’m now confused??? The engine numbers you posted are for a gear reduction engine, but this is on a pressure washer. What am I missing??
Hammermechanicman
Yup. A Briggs Chonda. I have had 3 of those in the shop for leaking crankcase gasket. I wonder if those are made by Loncin in china for Briggs?
That is what the engine serial number is coming back as. Maybe they didn't use the gear reduction when they mounted the engine for pressure washer use. Either that or an incorrect serial number is posted.
@StarTech I have seen cases on the Briggs power portal were two different engines show up by serial number depending if spaces are put into the sequence at the correct locations. Like for instance 1234567890 will give one engine but 1234 56 7890 gives a different engine.
