Most likely location of the model type and code of the engine is on the side of the valve cover, But some of the newer engines have the information laser etched into the mounting flange to the right of the drain plug.
Rivets, the 020646 00 is a Briggs model number for the pressure washer made for Husqvarna. But doesn't show engine info.
