fairlaniac
I've been having an intermittent issue with cylinders cutting out or weak. Here is a typical issue. I start the mower and it has a sputter. If I add choke it smooths out somewhat so I continue to mow. If the choke is off it smells rich. Adding the choke kinda clears it up. So with the engine hot I'll pull a spark plug wire to see which side is cutting out. So today I pulled the right bank plug and it keeps running without a change in sound or rpm. I put the plug back on. Then pull the left plug and it shuts off. Tells me the right cylinder is the issue. So I take it apart and get down to the coils. I clean and reset the gap. Put together and fire it up. Still the sputter and it still smooths out with a little choke. So I pull the left plug to see if it will shut down again. It keeps running. I put the plug back on and pull the right plug and it shuts off? So you'll see it randomly switches cylinder banks randomly.
This is a typical sequence going on for the past year. Every other time or two it will start fine and run on both cylinders.
One note, I usually use a temp gun to check external heat where the exhaust pipe connects to the head. Usually on the cylinder that seems cut out the temp is about 100 degrees lower. So to me it is generating some heat. When I pull the plug to the "dead" cylinder you can see a weak spark. On the cylinder that is working when I pull the plug there is a bright and active spark.
I thought about just buying parts until it's fixed but that is stupid. I have thought of buying two new coils but nothing indicates they are dead. I have also checked the connectors and cleaned them. I have not run any electrical diagnostics, electric baffles me, I'm more mechanical. Any ideas?
Thanks,
Doug
Thanks,
Doug
