Lawnmauerman
- Apr 6, 2022
- 3
Good afternoon. I have a 2017 54"rzt zero turn with a little more than 100 hours on it. Towards the end of last season, I was having starting issues. When I would turn the key, I would hear the starter engage and stop. I could get it to free up by rocking the mower back and forth. Well I took the starter apart and the magnets inside were busted so I replaced the starter. Didn't solve the problem. The battery wasn't "bad" but wasn't new so I changed it and it didn't solve the problem. The key switch was suspect so I changed it, didn't solve the problem. Changed the solenoid and it also didn't solve the problem. I have popped a few fuses if that helps. Also when I hold the key to the "start" position , I hear a whining. Not mechanical but kind of like an electrical whine if that helps. I will offer any more insight if I remember. I've inspected the wiring for damage and found none so any suggestions would help. Thank You
