crazy charlie
- Nov 18, 2018
- Threads
- 14
- 89
Will get a pic and try to get a model # .I just bought an older rwd mower .Cast aluminum deck.Older style handle with 2 levers.Left is old style
choke lever and right side lever looks like 3 speed drive lever and a pull crossbar between the levers.Rear bagger with a difficult looking bag setup.
hope the description helps identify it.Starts on 1st or 2nd pull and seems to run and cut well.Spark plug is on left side of motor when operating.
Has a champ plug but I thought I was reading a plug number but it turned out to be a word like "energy" or similar,sorry I dont recall exact but I
want to replace it as it looked a bit on the white side .Also has a unique looking mulch blade which has 2 smaller blades coming off of the main blade.
Gonna need sharpening for sure.Also want to change oil which looks to be a pipe thread accessed from the bottom of the motor by the blade.Only
spent $50 but hope I bought a good one.?? Any comments are appreciated.Thanks Charlie
