- Feb 19, 2020
- Threads
- 121
- 12,884
The problem with just checking to passages are clear with spraying fluid into passages is there are some cross passages that can't be visual checked like those around the non removal nozzle.
When you say idle screw, are you talking idle mixture or idle speed? If it needs a choke, you most likely have plugage in the carb if no mixture setting makes a correction. There is also a service buletin on that carb system. Model info - means I do not research it.Did you set the high speed mixture first? My experience tells me to always set high first, then idle.
