49065-0721 Kawasaki OEM Oil Filter replaces 49065-7007
RayMcD
  • / 49065-0721 Kawasaki OEM Oil Filter replaces 49065-7007
Is this legit ? I can't get any info off the Kawasaki engine site.
Been using OE 49065-7007 since day 1, now filters I have coming are said to be 49065-0721.
Here's a list of filters that will work,
WIX 57035 32 micron (2.3 tall)
WIX 51056 21 micron (2.7 tall) 51348 (3.4 tall)
WIX 57148 5 micron (3.4 tall)
PH8170
I for one prefer the WIX 57148, Cheers, Ray
Again, it matters very little which filter you use
Mower engines are crude rude & unsofisticated .
All of the specs for them are just about identical
The only real difference is the external size
The only important thing is the internal bypass valve but in most cases you would have to run the engine 10 hours a day 365 days a year for 5 years to totally clog the oil filter to the point that the bypass activates
7394
While under warranty, I'll stick to the K Tech filters..
MParr
Have you thought of using a paint pen to mark the hours and date of change on the end of the filter?
7394
Yes Sir, I do that, & I have a log book to record each mow time, & what has been done etc, thru the year, so I have records. Not just my old memory. LOL. ..
hlw49
Finally go a chance to check on the new filter no. that replaces all the other filter nos. 49065-20721. Made by the Ja Pan company. LOL. Has round o ring and is about the same size as the 49065- 0724.
Scrubcadet10
Moderator
Staff member
20721 or 2071?
7394
Wow, I can't find that new # anywhere ? Even on Kawasaki site shows the 49065-0724 only.........
