Have a pressure washer, 20 years old. Briggs 4 hp quattro engine. At the base of the carb are two gaskets/diaphrams where it sits on the fuel tank. The engine is very hard starting. Once it gets going it is fine. The primer bulb will fill will fuel in two or three pumps. In late October 2021 I once again replaced those gaskets/diaphragms and the engine was fairly easy to start. Now it is late Feb 2022, new fuel and once again it is hard to start. Air filter is a green universal one instead of the factory one. After pulling maybe 20 times I removed the air cleaner and tried it again. It started on the second or third pull. Does anyone have any experience with the engines that have the carb on the tank, where they are able to easy start their engine, and keep it that way for years without having to replace the carb etc once a year or two? Also does anyone have any experience where some of the universal air filters are too restrictive and they are the cause of the hard starting?
It is this style carb and tank, and filter. Photos are from the Internet. The filter in this image is the Briggs factory filter. The universal ones are a green dense foam.
