earnest t bass
- Feb 26, 2020
- Threads
- 16
- 54
can a in-line fuel filter be put on model 10515. the run from the tank to the carb is pretty short and works on  gravity. can it be done
			I don't see why not. I have in line fuel shut offs on both of my 10525's.can a in-line fuel filter be put on model 10515. the run from the tank to the carb is pretty short and works on gravity. can it be done
I don't have a service manual that new, but I my 1992 manual shows an inline filter built into the inlet of the Walbro carburetor. Have you checked to see if yours already has one? Or is there another reason you are thinking about an inline aftermarket filter?can a in-line fuel filter be put on model 10515. the run from the tank to the carb is pretty short and works on gravity. can it be done
The Briggs and Stratton Fuel Filter for gravity fed installations uses a screen instead of paper and is very compact in size.(.Paper filters should only be used when there is a fuel Pump) ....Check it out here >>> https://www.ebay.com/itm/265149919567?hash=item3dbc2ab14f:g:uY0AAOSwM6NgkzT7can a in-line fuel filter be put on model 10515. the run from the tank to the carb is pretty short and works on gravity. can it be done
