- Sep 24, 2017
- Threads
- 280
- 6,789
I've had 3 failures of stens solenoids this year, same part numbers as well. and one on my own equipment just the other day.
anyway i replaced three total in 2021, one of which was on my Mule.
i repaired one mower back in the spring, March i think... that solenoid failed in July. i then went back with a OEM Kawasaki part.
i replaced another one in May, an it failed in October.
i replaced the on on my Mule in august and it failed last week.
Now the kicker is, they all failed the same way, you turn the key, and it doesn't retract or anything. just barely moves... i load tested the trigger wire by using a 12v30W tailight draw on it and it never dimmed. or flickered. So it appears the solenoid just gave up, and all in the same manner.
so it seems to be a stens/supplier issue.... so far the OEM kawasaki's are doing good.
Stens 435-864
I keep several of these on hand as i service a few older kawasaki Mule's which use the solenoid shift starters.anyway i replaced three total in 2021, one of which was on my Mule.
