Skip Z Force 60
- Jan 5, 2022
- 3
Model 17ASDGHD056 SN 1C208H60075 2018
Hi all, i replaced the battery around a year ago (Walmart). The engine turns over1/8th to maybe a full revolution and then stops. It does this with a battery charger on ar 40 amps also. Put the battery on trickle charge for a few days it showed full charge. Is this a battery issue or a starter issue or something else i havent thought of?
Thanks in advance
Thanks in advance
