I am having difficulty finding the correct part number for a mulch plug that will fit an HRC216 pictured below. I would not mind the numbers for the bag/frame as well. thanks. just picked this machine up but no parts came with it.
Sorry I forgot you wanted bag kit too
Honda 06813-vk6-610 bag kit, grass
look on internet. Prices all around. $100.00 plus up to $150.00
good luck
a rear / side discharge kit is also available.
honda 06814-vk6-000. Approximately $50.00 range
btw you have what is called A Honda HRC216HXA. It’s a K3 model.  K3 is the 4th generation of Honda commercial mower. Was a hrc216 from 1989 to 1995.  Hrc216k1 from 1996 to 2005.  Honda hrc216k2 from 2005-2007. Hrc216k3 from 2008 to current day.   Honda doesn’t have any model years but I know when they made them from if that makes sense.  Just double check your serial number but your picture is definitely a K3 model which is current.
