If you have spark it's not a killer switcher.This little critter won't start. Engine has compression fuel and spark. Will not start with starting fluid. What the heck? Kill switch?
Will pull the carb and clean it tomorrow.If you have spark it's not a killer switcher.
Bet a wooden nickel a dirty carb slash fuel delivery issue is to be found.
Will do. Thanks for the tip. To my knowledge the owner did not hit anything with the mower.i would pull the flywheel nut off and check the flywheel key.
should make a perfect square in the slot.
Flywheel key is fine.i would pull the flywheel nut off and check the flywheel key.
Have cleaned carb this afternoon. It was dirty. Blew out what I could and cleaned the filter. Diaphragm appears weak look for a replacement tomorrow.If you have spark it's not a killer switcher.
