shurguywutt
- Jul 17, 2013
- Threads
- 30
- 231
Hello everyone, my trusty Toro PowerVac has started to go on the fritz. I am pretty handy with small engines and I like to DIY so I have been troubleshooting/swapping parts/cleaning this thing for about a month already, unwilling to give up the fight and have this dang small engine defeat me. I am about to give up on it and just go buy an Echo blower (before gas equip is illegal lmao).
First let me give you the info: 2013 Era Toro 51987 PowerVac.
Carburetor: Walbro WYC-7-1 or something very similar with no adjustment :-(
I bought a cheap Chinese Walbro replacement on amazon and installed it, no change.
I stripped the the OEM Walbro carb and cleaned it up good in an ultrasonic cleaner, no change.
Fuel lines/primer is new.
Fuel filter is new.
Air filter is new.
OEM spark plug is new. (Champion RCJ6Y)
Spark arrestor is clean.
Muffler is clean.
Replaced gas cap (vent was bad).
Heck, I even thought my 2-stroke fuel ratio was bad so I got some fresh Rec90 fuel and mixed a perfect 50:1 ratio and refilled the tank. (all my other 2-strokes love what I feed them).
So all of the above has been a process of over a month working with it. It started by me having to blow a bunch a debris and clean up after my weekly mow ritual. Of coarse that is always how it goes. So the thing basically died and it would not start back up, I am pretty stubburn so I fought it for 20 minutes before I gave up. I figured alright, let me replace the carb, filters, fuel lines, etc. Did that and got it up and running again fine. Then it started bogging down the next time I used it. Thats when I started looking at more things on the list above. The last thing I replaced was the gas cap because it would build up quite a nice vacuum after using it for a while and then it would bog down and die. I thought for sure I figured this out because when I removed the gas cap there was a lot of suction. After this I ran it with the gas cap cracked to let air in. It ran fine at full power. Then I replaced the gas cap with a brand new OEM one that I tested the vent and made sure no vacuum occurred. It ran fine but started bogging down at high RPMs.
It starts fine on choke, then I have to run it at half choke for about 2-5 minutes before I can take the choke completely off and get full power. I was testing it out this morning again because I have to mow on Wed. and I wanted to make sure it's working; I fought with it for another 2-5 minutes on half choke. Every time I would go to no choke it would bog and die. I finally set it on its side to take the (brand new) gas cap off just for giggles, no vacuum in the tank, I thought ok good, screwed the cap back on, set it to run, first pull crank right up, super responsive. What gives?
Fuel filter is new.
Air filter is new.
Muffler is clean.
