intruder1500
Anyone know the OE part number for the subject side mount grass catcher bag. Looking to find an original part if possible.
Close but mine has no handle. There is just a cloth strap that hangs on the wire frame mounted to the handlebars and the chute has no handle....just a rectangular wire frame built into the end with a slot that the chute clip mounts to.Try Lawn Boy #89816.
I found a pic of the bag on My Tractor Forum ....the rod for the bag is not the same..... mine mounts to the side handlebar but the bag appears to be identical.Try part numbers 89800 or 89801. Only three bags which came with that model number, depending on serial number.
| 10525 MINE | 8903456 |
| 10525 NEW ONE | 9902098 |
| 10525 PARTS MOWER | 8903443 |
That's where I got the part # 89816 in my last post. Unfortunately there is no picture of the part and they will not ship to Canada.Type in your model and serial numbers on this website and you will find which bagging system was used on your unit. https://www.shoplawnboy.com/Comerge...nlineModelLookupSearch&search=model&OP=filter
Unfortunately every site I go to shows a pic of the 89816 upgraded bag with the 3 holed handle and different attachment to the chute.That’s the number I listed in post #2. Just type the number into your search engine and you should find a picture and source.
