- Nov 29, 2014
- Threads
- 64
- 24,705
And I have a 1926 BSA B2 that I have done about 125,000 miles on using SAE 30 mower oil and BSA never specified mower oil
The landlord had a set of 2000 series Cub Cadets that we mow the orchard & paddocks with to the tune of around 300 hrs each per year and they run SAE 30 in the Kohlers as well .
The oil that goes in is nowhere as important as how often it comes out .
We had a club member with a 1966 A65 that would not hold pressure at idle when hot when he bought it.
He did 180,000 km on that engine running Valvoline 20W50 and sold the bike 20 years latter with the same worn timing side bush as it had when he bought the bike .
And BSA recommended a bottom end strip & rebuild every 30,000 miles , Rhett never touched his apart from changing the oil at the end of every run .
So you point, is pointless
No such thing as a super oil that will make an engine run forever .
I had a fleet of L300's all of which went for more than 1,000,000 Km without a bottom end failure and they were run on reprocessed 20W50 strait oil and these were all LPG powered so supposed to run LPG rated oil.
Mower engines are trash , the bulk rely on splash apart from the big end for lubrication so the oil used makes little difference.
Now the XJ650 & XJ750 we used to run ( 12 at one time ) all have metering jets on each cam & crank journal and all of them are different sizes because oil pressure & volumes at each journal is citical and carefully calibrated , running a thinner base oil in them would be a disaster.
Then we come to Hydros
If you have ever pulled one down you would see there is no seal whatsoever between the cylinder body & the valve plate.
The hydro companies machine these to a specific roughness so the resistance to the oil leaking is higher than the resistance of the oil pushing they pistons .
There the wrong oil, and in particular using a synthetic with a lower specific viscosity will cause premature failure .
And the opposite will also happen as with a slower flowing standard oil there will be insufficient flow to float the surfaces.
