Hello folks,
so one of those engines with the plastic carbs without a primer bulb, with the white "cartridge" in it, a 625EXI engine has issues with the RPM/throttle surging up and down.
Before this happend, the engine refused to run properly at all, so I took the carb apart, cleaned it, the ports too, replaced spark plug, placed a new filter and it run great. But after a hour or so after mowing, it started surging heavily, no matter if there's a filter on or not. Only thing I noticed is that the carb bowl is very oily/wet overall.
Not sure what to try since the carb has been cleaned already. No way to tune it or anything, so I'm out of ideas.
Video and image: (don't forget to turn sound on)
Thanks anyone in advance for any help given!
