Blade Shaft/Pulley Falling
Ericbss7
2010 Craftsman LT2000
Driving along mowing and all of a sudden i start to hear a noise from the deck every time I disengage the blades, like a violent banging sound. Also start to smell rubber. (Yes at this point I should have stopped but I didn’t) Few short minutes later I can’t engage the blades anymore so I turn it off and pulled the deck. Naturally I found a partially shredded belt (rubber smell), but I also found that one of the blades was very low, against the ground basically. Aside from the blades being torn up, which I expected, I noticed that the shaft of that one low blade was coming out of the mower deck (see image). The other was still tight to the deck. I’m able to bang it back up with a rubber mallet, however it’s very loose and will definitely fall again once I turn the deck upright. I have no idea how these shafts/pulleys are held in place, I didn’t see any obviously bolts, etc. Apologies for the ignorance, just trying to find out what I need besides a new belt and 2 new blades!
Top bearing has failed. Remove the nut holding the pulley on and remove the pulley from the top of the shaft and drop out the bottom of the housing and replace the bearings, and put it back together. Unless the shaft is bent no reason not to just repair the spindle
Scrubcadet10
Moderator
Staff member
941-0919B​
is the OEM bearing number, or i believe that is a standard 6204-2RS bearing
Ericbss7
Thanks for the help everyone! Appreciate all the quick responses. Time to order some parts.
Time to pull it apart, see where the problem is then order the appropriate parts
Cusser
I have an LT1000 in a small town, and I order spindle, pulley, blades, belt as a kit. I always have a spare spindle/mandrel and belts on hand as these do wear or break.
I've seen a John Deere unit that has grease fittings on its spindles.
Joed756
If you pull the spindle apart you will see (usually) that the bearings are sealed and those zerk fittings are giving you a convenient way to waste grease.
